'06 MS6 all out build
  • Thread starter Thread starter Sho
  • Watchers Watchers 25
Sho
Silver Member
The time has come to finally get my built motor going after spending a year recovering from the previous machine shop fucking my block and sleeves and leaving me high and dry.
Parts on hand:
-2 spare short blocks with good cranks
-spare head
-Darton Dry Sleeves
-King TriMetal pMax black rod and main bearings
-Freektune H11 head studs
-ARP main studs
-Ecoboost oil pump
-all timing components
-Kelford 247-C camshafts
-Kelford 83lb valve springs
-oem valves
-Wiseco Custom 12.5:1 CR pistons with deep intake and exhaust valve reliefs
-H13 wrist pins w/ .250" walls
-Total Seal High tension piston rings paired to match my custom pistons
-Manley H Tuff + rods with 625+ rod bolts
-Massive Speed BSD plug
-Massive Speed Oil Pan baffle
-SP63 Billet Transfer Case Bearing Caps
-OEM rear main seal
-RamFab firewall master cylinder brace
In transit:
-Xclutch Ceramic Twin Disc rated for 1300 ftlb tq
Machine work to be completed
-Darton sleeves installed, bored and honed to 87.5mm 280 grit, 23* cross hatch
-block and head decked
-oringed block and head
Parts carrying over from my stock block setup:
-PTE 6266 GEN 1
-Cp-e vband exhaust manifold
-Kozmic DP
-CS CBE
-DTPFAB dump tube
-PTE PW46 EWG
-Tial Q BOV
-DWR modified fuel pump basket w/ TI automotive Hellcat 525 LPH pump and radium venturing (may be replaced with @Maisonvi
Version if he gets around to completing it any time soon)
-Aeromotive FPR
-BC Racing coilovers (rear springs will be upgraded to 700lb)
-Whiteline RSB
-CS Strut tower bar
-SURE rear diff mounts
-JMF w/ PI
Goal:
-Efficient power on lower boost with good transient response
20200210_164301.jpg 20200210_164543.jpg 20200212_202502.jpg 20200212_202552.jpg 20200212_202608.jpg 20200212_202622.jpg 20200212_202632.jpg 20200212_202638.jpg 20200212_202733.jpg 20200212_202903_HDR.jpg 20200212_202927_HDR.jpg 20200212_203008_HDR.jpg 20200212_203018_HDR.jpg 20200212_203030_HDR.jpg 20200212_203306.jpg 20200212_203312_HDR.jpg 20200528_220257.jpg 20200528_220303.jpg 20200210_164649-02-01-01-01.jpeg received_1790618481120458.jpeg
Sounds like a crazy solid build man can't wait to see how it goes! You should make a post about the xclutch as that is the one I am planning to get as well when the time comes curious if the pedal is much stiffer along with whatever else you learn about it from install etc :)
Oem mzr DISI crank since I have 2 in perfect condition. Otherwise, id grab an ecoboost crank
Quick question about the crankshaft... is it the one from the Focus RS or Mustang Ecoboost that can be used in the Mazdaspeed? Are there any differences or advantages\disadvantages of using the Ford crankshaft?
Are you going to use the OEM MZR crankshaft, or the ecoboost crank?
From what I've heard, the pistons, rods and crankshaft have the same part numbers.
On that note, I've used the one from the mustang.
M-6303-23EB and
LB5Z-6303-B both work.
