Front Suspension Wheel Alignment (unloaded)
Total Toe-in
Tire .08" [tolerance +/- .15"]
Rim Inner .04" +/- .12"
Degree 0 degree 11 arcminutes +/- 11 arc minutes
Caster angle
3 degrees 8 arcminutes [tolerance +/- 1 degree]
Camber Angle
57 arcminutes [tolerance +/- 1 degree]
Steering Access Inclination
14 degrees 21 arcminutes (reference)
Maximum Steering Angle
Inner 36 degrees
Outer 30 degrees 12 arcminutes
Rear Suspension Wheel Alignment (unloaded)
Total Toe In
degree 11 arcminutes +/- 11 arcminutes
Camber angle
-1 degree 42 arcminutes [tolerance +/- 1 degree]
Thrust Angle
0 degrees [tolerance +/- 48 arcminutes]
