Anyone have a data log or vd/dyno of before and after the TB with no other changes?
Stop selling shit via PMs.
But his mouth is so soft....Ban that Kiwi guy! Trouble maker, he is!
Power bottom all the way.difference i pitch, you all are all about catching
Ive been blueballed..... the oring on oring action is a no go so this can't be used on a st mani.. sonofabitch...
You also live in California so you lose.Do not be mad that it is 70 degrees outside and I run summer tires year-round.
Stock manifold is much smaller and it works on that. and jmf isnt much bigger (unless you get the 75mm jmf tb opening). Works on thosePretty sure the hole on the st mani is too small
Speed solutions is making an adapter to go between the cs tb and st mani.
Is the OEM manifold big enough to allow the corksport throttle body to open allow the extra flow in? I've never bothered to measure the OEM manifold opening, and I'm too lazy to dig through the old forum for the specs. I'm curious about the off throttle hesitation you get with it.
@Sho is currently running it on a PNP oem mani, though i don't know if the tb inlet is ported or just the runners. maybe he can chime in with his impressions.Is the OEM manifold big enough to allow the corksport throttle body to open allow the extra flow in? I've never bothered to measure the OEM manifold opening, and I'm too lazy to dig through the old forum for the specs. I'm curious about the off throttle hesitation you get with it.
well here are some HF measurements. The battery was dead so had to eyeball it.
Can some one measure the ST mani opening?
Mani opening
This is what it necks down to right after the opening
this is what a meth adapter can give us
