KingScumbag
I agree. Just seent it. Johnny Van in TN had this done. He had weld cracking issues. I think they were poop welds. Weld to cast is no fun to do. Proper weld is proper.
I have to say, for welding on shitty cast, whoever did those welds knows what they are doing. Thats pretty impressive.
This was an $80 job, $20 of it being for a t-shirt repping his shop. Brett is awesome and does some crazy shit. He's a DSM guy from what I think I know.
https://instagram.com/iambr3tt?utm_source=ig_profile_share&igshid=1fk8ey6r6v4s1
Super cool dude. If anybody is local to me/the Westland area, this is the dude.
What IM are you using again? ST?
And the dead head system is fine, I ran one and its ok, but it can limit you for sure. Granted your turbo and other things might limit you first.
Using a stock manifold and the Damond spacer kit. Trying to track down a Relentless PnP manifold, or comparable stock PnP manifold.
I know it will limit me. I will more than likely add a return and FPR, but just to get started this should be okay.
I'm gonna see where it takes me. Would be cool to see where I can get using a stock ported manifold. I've seen people on big power using a stock manifold, but we'll seeA ported manifold will limit you a ton. Not sure you can make your 500 goal on that with a S4 pushing the air.
Sent from my Pixel 3 XL using Tapatalk
That's the plan right now. I will be going as far as I can with the stock manifolds and get a concrete number of where it starts to hinder thingsThe S4 can shove a lot of air into your engine but the main issue is the flow imbalance.
You can always swap them out later but it is a little when the engine is out already.
You want all 4 cylinders making the same AFR. By balancing the 4 cyclinders you add lifespan and power.
The stock intake and exhaust manifolds leave a lot to be desired in terms of balanced flow.
It would be cool to see this build makes on stock manifolds, then swapping on some proper ones.
I'll be contacting my repNone of this work is union approved. Get out of here you hack.
Following for ideas haha
watch your mouthSlow.![]()
