well its getting hot out again and the same problem year after year so far still plagues me. Im using 3M double sided foam rubber tape to mount my AP base to the left console just beside the ECS button (gen pu). The hot sun and temps soften the adhesive and eventually the AP ends up on the floor.
What is anyone else doing for mounting?
Jason
I use the same Cobb mount and stuck it on the same location; just beside ECS button. The trick is to not leave the AP mounted when you leave the car. The extra weight of the AP plus the Texas heat will soften it up to the point where it just falls right off. You can easily unmount the AP and leave it facedown on top of the steering column (with the cable still attached so you don't break the stupid clips), or you can store it somewhere else in the car. I also make it a point to press down on the mount for a good 2-3 seconds before mounting the AP back on. Ever since I've started doing this, I've not had any problems with the mount falling off.
