jdab555
So I bought Cooling System Test and Refill Kit (harborfreight.com) - coolant vacuum kit from Harbor Freight recently, finally put it up to the test today. The vacuum is supposed to evacuate all air from the system, and then that same vacuum will suck coolant from a container into the system, ostensibly filling it without any possibility of air pockets.
Worked well from what I can tell - to test for leaks, you hold it at max negative PSI for 30 seconds once its stabilizes, and then watch it for 1-2 minutes with the valves closed to check for leaks / gauge dropping. Watching my vacuum, I could tell that air slowly leaked in from somewhere, at the rate of ~1psi reduction in vacuum per 50-60 seconds, this coming down from a max vacuum pressure of -25psi. This doesn't seem to scream massive overheating-levels of compromise to the system's pressure integrity, but what do I know. I couldn't hear from anywhere that it was sucking air into the system, in a totally silent garage.
On the plus side after doing this, my heat is finally blowing hot, which it wasn't before.
At this point, I am basically narrowed down to 2 options, let me know if it sounds feasible:
Curious about what I should try next.
- Water Pump
- Blockage in the radiator / system somewhere (at this point the system has had the coolant changed out ~3 times, plus the vacuum treatment today)
