Hello All,
I recently ran into an issue with not being able to get boost past 24-25psi on my BNR S4 tune.
I am not quiet sure what the issue is so I wanted to reach out to see if anyone else had the same issue or saw something in my logs that looked familiar. I fixed an exhaust leak and have tightened down all hose clamps to make sure it wasn't something easy to fix but the issue still persists. I have a fully forged engine so it can handle the power. I also run a 3 port EBC and 3 BAR MAP and can upgrade to a 3.5 BAR, I just need to install it.
A little background, when doing my first logs on the set up I hit 16-16.5 PSI with 0 WGDC. (Log attached)
If you look at the attached logs you will see my PSI reach 24psi at 70 WGDC and it can't get any more boost even when the WGDC is at 99-100, which should not be the case from what I have seen BNR S4's give out.
If you can help, please chime in.
Forgot to add I am spraying meth through a D014 nozzle and the g/s for the MAF has been adjusted to compensate for the extra fuel.
