We recently moved farther from my work, so I was shopping for a good commuter to supplement my 4Runner. I wanted something kind of fun (turbo(?) and manual), then this Speed6 popped up just down the road. Went for a test drive and bought it the same day. PO used it only for commuting w/ 147,000 miles. I knew nothing about Mazda, let alone the Mazdaspeed6. Brought it home, drove it about 20 miles to the next town, and it threw a cyl 3 misfire code on the way home... Good investment. I pulled the spark plugs... Lawd have mercy. They looked like Civil War relics, so I replaced those and knew I was in for catching up with a lot of preventive maintenance.
I bought it on April 16, and I've since changed the plugs, cleaned the air filter/throttle body/intercooler/engine bay, oil change, trans/PTO/rear diff fluid change, replaced all soft lines in power steering system/flushed and filled, and have waxed the dogsh!t out of the paint as it's badly faded on the hood and roof. As you can see, looks like the PO used a mix of coolant and power steering fluid where ATF is called for in the PS system. I also noticed soft steering in right turns/harder steering in left turns. Everything online talks about the passenger side MM going bad, so I replaced that - the OEM mount had failed BADLY, and it drives and shifts a lot smoother now.
While going through things, I confirmed the following upgrades.
COBB Accessport w/ Stage 1 tune uploaded
COBB EBC
SURE Short-shifter plate and stainless shifter knob
SURE Cold Air Intake
SURE Oil Catch Can
James Barone Racing rear and driver side motor mounts
Unknown down-pipe with cat delete
Turbosmart BOV w/ recirc plugged
Autometer boost gauge mounted in driver dash A/C pod
I've had the car for 9 days, and it has been jacked up with me under it 8 of those days. These things are a blast. I know that I need to confirm whether or not the high pressure fuel mod has been addressed, but is there anything else you'd recommend as a maintenance item to check in on? Seems like whoever owned it prior to the guy that I bought it from took good care of it and upgraded it with quality/tasteful mods.
COBB EBC
SURE Oil Catch Can
