brandonf speed6 bt build
brandonf
Car: 2006 Mazdaspeed 6 (Liquid Platinum Metallic)
Motor: From Downmented: (RUNNING)
- Speed Perf6rmanc3 built long block
- Bored .20 over
- Custom Wiseco 10.6:1 Compression pistons
- Manley I-Beam rods
- 11mm H11 head studs/ stock head gasket
- Keyed Crank/ pinned cams
- Stock camshafts with 65lb Crower valve springs
- Single runner intake CnC port work of the head
- Ported exhaust side
Turbo: From Downmented:
- PTE 6265 (installed) (I have doubts the turbo is this big, I think I remember him saying it's like a 5654 or something weird)
Transmission:
- Pu gears + ms6 final drive (installed)
- Imoto 1/2 and 3/4 brass shift forks (installed)
- Clutchmasters 850 Race twin disk clutch (installed)
- SP63 transfer case bearing caps (installed)
- DSS Axles (acquired, saving for backups if needed)
Fuel system:
- Radium Engineering 3-pump surge tank (installed)
- (4) Bosch 2000CC PI injectors (installed)
- JMF v2 PI Intake Manifold (installed)
- AEM adjustable FPR (installed)
- Split Second controller for 4 injectors (installed)
- Fuelab fuel filter (acquired) <--- need to find in the garage somewhere :/
- Evilenergy e85 ready fuel injection hose (3/8", -6an) (long runs installed, need to order another ~20 ft to complete everything)
Exhaust:
- CPE Single exit cbe (installed)
- Steedspeed top mount t4 twin-scroll Exhaust manifold (installed)
- ? V-band Downpipe (installed)
Suspension:
- H&R coilovers (installed)
- CS Upper control arms (installed)
- AWR Front endlinks (installed)
- Steeda rear endlinks (acquired)
- CS Adjustable rear camber arms (installed)
- Whiteline rear sway bar (acquired)
Wheels/tires/Brakes:
- Enkei pf01ss 17x9 +48 (installed)
- Hankook Kinergy ht737 tires 245/45/17 (acquired)
- Evo 8 front brakes w/ Ferodo ds2500 pads (installed)
- Muteki SR48 lugs (acquired)
- ARP extended studs (not needed)
- Techna-Fit Stainless Steel Brake Lines (installed)
- Eiback 15mm hubcentric spacers (installed)
Mounts:
- JBR Trilogy PMM/TMM/RMM (installed)
- TT Front engine mount (installed)
- Whitewidow front differential mount (acquired)
- CS Rear differential mount (acquired)
Other:
- MDM Power steering cooler (installed)
- CS Front Strut bar (installed)
- CS Rear Brace Bar (acquired)
- Tial QR BPV (installed)
- 4" intake (installed)
- ? FMIC (installed)
- TR1035? intercooler (installed)
- 4 bar MAP sensor (installed)
- WOT box (acquired)
- SP63 Breather cap (installed)
- Sparco Evo II US racing seat driver side (acquired)
- APR Front Splitter (acquired)
- MD Dual catch cans (installed)
- Cpe 3 gauge mount (installed)
- VEI Systems Boost gauge -up to 90 psi (installed)
- AEM Failsafe Wideband AFR gauge (installed)
- ProSport Oil Filter Adapter Plate(installed)
- HTP OEM Battery Trunk Relocation Kit (installed)
- Redline Tuning QuickLIFT ELITE Hood Struts (installed)
- Techna-Fit Stainless Steel Clutch Line(installed)
- Denso Iridium Power Spark Plug ITV24 (installed)
- CS Injector Seals (installed)
- CS e85 fuel pump o-ring kit (installed)
- Tanabe oil pressure gauge (installed)
I still need to get the tires mounted/balanced, an alignment, and an inspection.. but the car is finally running again!
Looks like a very solid build. You definitely have the car kitted with some nice and hard to find pieces, also pieces hard to find info on. If you feel up for it definitely help out the community with some how-to’s and parts reviews.
I noticed the 10.6:1 Wiseco pistons in your build. I’ve been interested in how small compression bumps help these engines with low end torque, but haven’t found anybody really doing it, so if you feel like sharing about those it would be awesome.
If you’re looking for a small cheaper brake upgrade, I’m in the process of acquiring Toyota and Mazda parts that makes the front brakes 2 piston floating calipers. I’m Gonna do a how-to when I do it, so keep an eye out.
Most of these are older parts and were installed on the car around 2015-2016'ish, but the car sat for about 8 years and I'm finally now getting back to it. I still have a few of the parts in the garage I need to install (wot box, diff mounts, rear sway bar, etc), but I have it back up and running again.
So, I don't have any pictures on the installs, and most of the parts went on at once (thanks to @Rokusek and @DISIFTW). I honestly don't remember what it feels like to drive it anywhere close to stock. Feel free to let me know what parts you're having a hard time finding info about and I can help fill you in.
For the pistons (custom Wiseco's), I believe that was the best option at the time the motor was built, and there's probably way better options now. This motor was built by sp63 for someone else, I just copied in the specs he gave me.
