What spring do you have in it that requires 35% WGDC?
On the EFRs, the wastegate flows so well that you need about 40% WGDC to get to 1PSI over spring...I don't feel like this is a bad thing.
I put the spring in ages ago, but I had a 4 port ebcs hooked up at the time, so I think an 8psi spring. I'll double check when I take it apart/clean it up. I attached the most recent log.
Are you applying paint before wrapping? Vinyl dosent adhere well to primer. Plus, If you paint it will need time to cure and offgas. 30-60d depending on paint type and application method.
- I added a yellow spring into the ewg along with the blue/black, so it's now at 17.4 psi, wgdc much lower now (found out the neat trick of blowing compressed air into the side port to compress the springs, very helpful when putting it back on!)
- I see rust coming through my original fix of the hood, so going to go ham on it. I'm planning to get the whole top of the hood down to bare metal, treat the rust better, and do a 2k epoxy primer using a paint gun i've never used. This should go well! Afterward, i'll clean/tack it properly before attempting to vinyl wrap it again. I've been more thoroughly researching this one before buying anything, so any recommendations are welcome.
