Eric Fuller
Hey ya'll...awesome forum here, wish I'd found it years ago. This is kind of a weird story, so bear with me. Hoping someone can help point me in the right direction.
I have a 2013 MS3 with ~70k miles that's always run like a champ. No issues, ever. Dead stock with no mods. Not even a DD; it's my "fun" car. I was driving it with a friend and the low fuel comes on. I pull over at a gas station where my friend remembers me filling the tank (as do I).
After I fill it the fuel light is still on and the gauge hasn't moved. I figure there's a bad sensor or fuse and make a note to check it. The next day the car dies, acting like it's out of gas. Now I'm thinking there's a larger issue with the car.
I tow it to the dealer, tell them the car has a full tank but is dying and the fuel gauge isn't responsive. They diagnose a bad fuel pump and a bunch of other garbage like coolant and transmission flush. I tell them to just install the pump since I have a mechanic I trust who can lmk about the other stuff. They end up installing an aftermarket pump because I guess they couldn't source an OEM? $800 later I pick the car up.
When I pick it up the tank still reads empty. I talk to the tech and ask if he had to drain the tank to replace the pump. He tells me the car came in empty. After he added a gallon of gas it started right up and he pulled it into the bay. I ask why they replaced the fuel pump and he mumbles something about excessive resistance. They knew I thought the tank was full and at no point disclosed that it was actually dry. I wouldn't have known if I hadn't asked the tech. This is the first time the car had ever run out of gas and I don't believe that one instance burned out the fuel pump.
The next day I drive the car and there's a strong gas smell. Back to the dealer where they say the gas tank was damaged during the fuel pump install. They install a new tank. I pick up the car again. No gas smell but now the car stumbles under anything more than 70% throttle. My long-term reliable mechanic is now telling me there's an issue with the turbo.
IDK what to do here. No way I'm bringing it back to that same dealer, but this seems like something that may be over my mechanics' head since he had to call a friend who's a Mazda tech to figure out it's the turbo.
Thanks for putting up with this long-ass message but I figured all this info was relevant. Any advice you guys can give would be hugely helpful. I love this car and just want it back to it's normal condition.
