Got my AIM MXm dash logger finally installed.
such a cool piece. It’s wired into the cars Canbus so it’s pulling all the stock info from the ecu but it also has 7 additional external inputs.
2 of those I will use for oil temp/pressure. In the future boost will also be displayed here.
on top of that I now have a lap timer that cannot be debated(people sometimes cry about using phones for lap timing) and I will have full data collection including G forces, speed, throttle trace, brake trace(not sure how great this one will be) and basically everything else ever. This will help me as I approach the limits of grip with the car. It’ll show me things like too much throttle too early, or not enough throttle early enough.
the laps are overlaid into a Google maps image of the track, where it then shows you your line through the corner, as well as any other data you may want. It’s pretty cool.
Wish I took some more pictures of install. I will once I have my car back home
Currently the car is at the shop having the tires swapped, alignment modified, and an exhaust leak needs to be found and fixed.
I leave for Michigan on Friday to do a lapping weekend at gingerman. I’m so excited lol
I have the shift light set, and am currently displaying rpm, coolant temp, and iat’s as well as lap time.
once I get the car home I’ll play with the layout some more and see what I really need. Probably keep coolant temp, rpm, laptime and afr listed.
speed I’ll swap out with oil pressure once I install the sensor.
