Have you disassembled the exhaust system to see if there are any soot markings on the exhaust?
A smoke test as stated above would work. The machine we use at work has inflatable bladders that go in the muffler, get aired up with a tire gauge, then connected to the smoke machine so it somewhat pressurizes the system.
Are you sure something isn't burning and is not exhaust? Maybe some type of insulation behind a heat shield? Or plastic/electrical/fluid that's getting burned off?
Is there an EGR on the motor or is that controlled with VVT? A lot of manufacturers have gotten rid of the EGR and controlled combustion temps through controlling valve overlap.
