Code Monkey
It does not look too torn apart.
Love me some good purple. I had the same idea for my car but I went with illusion blue. Looks good man, slowly but surely coming along!
Sent from my VS986 using Tapatalk
Flows 76lbs/min. Compressor inducer is 62mm and exducer is 84mm. Here's the compressor map:
Wow, thats a lot of flow. I would say spool is going to kill you but you are going TS so that will help a ton.
Better start getting them LNF Injectors to work... youre gonna need it lol
Well it's been a while since I've updated this but the car is 95% together and running. Just need to finish up some exhaust bits. I made the switch over to Versatune and am loving it. My basemap is on the car and it idles good but I can't take it out yet until I finish the exhaust.
Curious to see how the VT works out for you. Depending on a few things, I might end up switching one day.
[doublepost=1463594908][/doublepost]
I also see you hiding an intake manifold.....
