Soooo.... my car wont stay running.
Idles fine for a while and then eventually, RPM will drop like i flipped the key off, the CEL and Battery light will turn on for a sec, then rpm will shoot back up. Never throws a CEL. All grounds are clean and secure. Crank position wiring in the past has caused similar issue, as the harness was rubbing on the passenger axle and caused a short. But when that happened, it would blow the ENG BAR 1 fuse. I replaced that section of the harness and all was well for a few months. The only thing I can think of is the Crank position sensor is taking a shit, and once the car warms up, is when it acts up. Or my ignition switch is failing.
logs are attached with highlighted sections of what its doing.
Car has 214k miles
Built motor has 52k miles
Clutch has 3k miles
Due to nature of my job, I drive about 1k miles a week, and the car is started and shut down 10-15 times a day, 5 days a week.
Car has 214k miles
Clutch has 3k miles
