So I found the issue....
I found this out a couple of weeks ago but I've been super busy trying to finish up my last semester of school (Thank God). We couldn't finish taking it apart because I didn't about the bolts on the crank girdle being torque to yield so I tried to zip one off with an impact gun. Ended up rounding it a bit and we finished it off trying to remove it with a homemade breaker bar. I bought some sockets that will hopefully work to remove it.
I've been slowly ordering/buying stuff for my build and I'll post more pictures when I get a chance.
So far I have bought in no particular order:
KW V3s
Quaife LSD
4 2200cc injectors
EV6 to EV1 connectors for the injectors
Double hump coupler for compressor to hot side piping
Darton dry sleeves
Down payment on the 16wfab intake manifold
I'm in the market for pistons and I have made my decision that I want to go with high compression pistons.
@Realgib3 and I were talking a few months ago and he basically convinced me on going that route just from our conversation. Plus you gain better efficiency overall; More power per psi, more TQ down low, better gas mileage, etc. The only downside is having to run a higher octane but that's really not an issue since E85 is plentiful in my area.
Now this leads into the compression ratio and what brand that I should go with. I was doing some reading on MSF about the Wiseco pistons not giving enough clearance for the oil squirters. I'm not sure if anyone knows if this has been resolved or not. My engine builder
@Need2pu doesn't like the idea of bending the squirter so it clears and I agree with him so I'm just trying to weigh my options.
@Enki, would you be able to give me some input on this? Mark told me he ran 12.5:1 and I'm thinking that's what I want as well which would mean custom pistons. I know your build, Enki, has the same compression ratio but obviously you achieved that ratio differently with destroking and whatnot. Any info is appreciated.
