Figured it was finally time to listen to everyone telling me to make a build thread.
My car is a 2011 Mazdaspeed3 base model that I have owned since March 22, 2020. I bought the car with 76,600 miles and as of the start of this thread on 02/20/24 it has 119,292 miles. I daily drive it, and have truly enjoyed it through every mile.
The primary idea behind the modifications I have done/want to do is to build a car that is as if Mazda decided to release a harder core, more aggressively tuned Mazdaspeed3 as an homage to its participation in motorsport, similar to how Subaru made the "S20X" versions of the STI, Nismo with the "Z-Tune" Skylines, Mitsubishi with the FQ Evos, etc. A car that is still retains its identity as unmistakably Mazdaspeed but increased significantly in capability from factory. This just so happens to align with the other primary goal I have for the car: to compete in autocross in the STH class, as well as the occasional track day. Not expecting to be inherently competitive, but to have a car that could take me there if I tighten the nut behind the wheel. My hope is to create a car that is drives freely and happily, feels good around the cones and the backroads, and is relatively reliable.
Current Modifications:
Engine/Exhaust:
Thanks for reading this far if you did. Here are a few shots of the car to close out this initial post:
^here with my friend's 1988 Mazda 323 GTX, these cars are two bookends of Mazda's hot-hatch library
Engine/Exhaust:
- Corksport SRI (stock diameter), AEM Dryflow filter
- Corksport Aluminum Turbo Inlet
- Corksport HPFP Internals
- Sure Motorsports Charge Pipes
- ETS Version 1 TMIC
- Tial Q 50mm BOV
- Generic 3-Port MAC Valve EBCS
- Damond Motorsports Stage 1 OCC
- Damond Motorsports RMM, PMM, TMM (Race bushings)
- Ultimate Racing 3" Downstream Cat Delete
- Ultimate Racing 3" Resonated Catback
- Accessport V3 with Freektune OTS+ (93 octane)
- Progress Competition 32mm Rear Antiroll Bar
- Moog Rear ARB Endlinks
- JBR Rear ARB Brackets/Bushings
- Whiteline 27mm Front Antiroll Bar
- Corksport Adjustable Front ARB Endlinks
- Moog Inner and Outer Tie Rod Ends
- Centric-Stoptech Brake Rotors
- Hawk HPS Brake Pads
- Rear Stoptech SS Braided Brake Lines
- Monroe OESpectrum Reman Rear Dampers
- Corksport Short Shifter Assembly
- Solid Shifter Base Bushings
- Cobb Shifter Counterweight
- Zero Customs Weighted Shift Knob
- Zero Customs Anatomy V2 Steering Wheel
- Black Alcantara Shift Boot
- Corksport LED Interior Lighting Kit
- TYC Reman Headlights (Lamin-X GT Yellow vinyl)
- Sealight H11/H9/H8 LED Low Beams
- Sealight 9005/HB3 LED High Beams
- Corksport Carbon Fiber Hood Scoop
- Rear Reflector LEDs (thanks PO)
- Way too much crap dangling from the rearview mirror
- Summer:
Motegi MR145 Traklite 3.0 Bronze - 17x8.5 +42
Bridgestone Potenza RE71R - 245/40R17 - Winter/All Season:
Factory 2011 MS3 Wheels - 18x7.5 +52
Continental ExtremeContact DWS06 - 225/40R18
(fronts have the updated DWS06+ due to recent shortcomings of the Indiana Department of Transportation and Continental having discontinued the original DWS06)
- Oil Used: Pennzoil Platinum 5W-30
Oil Filter(s) Used: Napa Gold 1348 (and Wix equivalent), Mobil1 M1-102A
Interval: ~3000 miles - Spark Plugs Used: NGK 3787
Gap: 0.026-0.028"
Interval: Unsure of proper interval, has been around 30,000 miles, surely needs new plugs by now
- Gear Oil Used: Tribodyn 75W-90 w/o LSD Additive (per suggestion of JT)
Interval: Again, Unsure of proper interval, has been around 40,000 miles, surely needs it by now - Coolant Used: Whatever was in the car when I got it, plus being topped up with distilled water
Interval: Eventually, I don't ever see abnormal coolant temps
- Looking to get valves cleaned sometime this year
- Looking to get VVT service along with timing chain replaced sometime this year
- Figure out the source of the weeping oil leak from around the oil filter area mentioned in my other thread
- Factory suspension is showing its age, hoping to upgrade to coilovers that are capable, adjustable, reputable/high quality, and not excessively stiff. Current options considered are Bilstein B16, Fortune Auto 500, and KWV2. I have yet to see reviews of more cost-effective options like the Corksport or Graveyard Performance coilovers in an autocross/track perspective.
- I currently have a set of Morimoto XB LED fog lights that are waiting for a warm day with free time to go on the car.
- PO did some hackjob wiring with the front left ABS sensor wire which added about 8 extra inches to it. Last year, it came dislodged from its clever hiding spot behind the upright and began contacting the wheel, causing a strange intermittent ABS and TC light. I've since replaced the wire with one from Beck/Arnley on Rockauto, but the new wire did not fix the issue and I've had the ABS and TC lights on for months now. I will look into it this spring and see if the wire/connector got damaged during install, or if I just need to get a new harness.
- Eventually the plan is to get a 3" intake OR the stock diameter Mazdaspeed CAI (rare and neat part), a 3" Ultimate Racing Catted Downpipe, and have the car full-tuned by Justin at Freektune for a reliable 280-310 whp and 300-330 lb-ft goal. I don't particularly care for big power, I am an amateur driver at autocross who already doesn't know how to handle the maybe 260whp the car has now.
- I would like to eventually get around to installing the Corksport Oil Filter Sandwich Plate along with oil temperature and pressure sensors and run them to gauges in the cabin.
