BAT-man
BANNED
Figured it couldn't hurt to gather some data from various instances of how clutches looked/felt/acted given usages and mileage.
Please post your experience in the below format, so we can have an understanding of how they wear.
A few things I hope we will be able to get a gauge on:
a) How long completely stock setups last before slipping, and what is the usage
b) How long aftermarket setups last before slipping, and what is the usage
b) If a clutch blew up/started slipping after a fairly short time, what was the setup and circumstances?
For the below, if you can tell that you put down certain power for X miles and then more power for Y miles, try to incorporate that.
1) Platform: MS3 Gen1/2 or MS6
2) Type of clutch/flywheel setup: Stock or aftermarket (if aftermarket, even if LUK, please state brand)
Flywheel:
Clutch:
3) Mileage on the setup / mileage you put on the setup (power levels as well):
4) Usage: (All street | Some track/drag | lots of track/drag)
5) Does it slip in any gear? If yes, what mileage did it start?:
6) Change in feel: (after how many miles of use did you notice a change in pedal feel and what was it)?
7) If you changed it, post a pic of what it looked like at XYZ mileage:
I'll throw my data out to get started:
1) Platform: MS3 Gen 2, 2 of them
Flywheel: Stock for both
Clutch: Stock for both
3) Mileage on the setup / mileage you put on the setup (power levels as well): 1st car 100K/all mine / 2nd car 130K/20K mine. Both around 280-300WHP/300-350wtq.
4) Usage: Some autox (3-4 events per year)
5) Does it slip in any gear?: Neither car's clutch slipped.
6) Change in feel: 1st car no change in feel / 2nd car around 120K started grabbing really high.
7) If you changed it, post a pic of what it looked like at XYZ mileage: No pics yet, will post when replacing clutch.
Flywheel:
Clutch:
