ExtremeCaliber
It seems whatever sensor it decides to read after roughly 5 seconds from the normal cold start sequence, that is making my afr spike, and plummet straight down. My stft starts off at 3%, then after a few more seconds, will plummet straight down to -25%. I'm at such a loss, I've spent most of the day going over any unclipped connectors which yielded nothing. I've tested boost leaks, and could not find one. I've reverted back to my original catch can setup (catch can between intake manifold and pcv vacle) and that hasnt changed anything.
What am I missing here? I wanted to assume my maf is bad, but I've got a spare oem from a cx7 (same model number and all) and that doesnt change. MAF has been cleaned possibly 7 times and obd2 readouts from either torquepro or forscan shows the exactly same values, hovers 2.7 g/s which is normal.
I wanted to assume O2 sensors but even that is reading normal from the obd2 (I assume). What the hell is causing my afr to spike, and plummet? I'll look up how to clean the pressure release valve for the fuel pump but my knowledge here is lacking.
