mituc
So after wasting about $1500 trying to diagnose the issue here: https://www.mazdaspeeds.org/index.p...old-issues-still-haunting-after-rebuild.8988/ I figured my spark plugs crack for some reason. They crack in the coil boot area as you can see in this picture here:
I finally realised that when I noticed similar marks on the supposedly new spark plugs after I pulled them after about 800 miles and compared with the old ones which also stayed in the engine about 250 miles and were replaced just as a precaution because I didn't know what else to do.
So far this engine cracked within about 1200 miles from the rebuild:
- two spark plugs on cylinder 1;
- two on #2;
- one on #3;
- none on #4 (yet).
Since the sparkplugs look normal on the cylinder side I'm not sure if I can blame the heat or anything else, since they worked absolutely fine with the previous engine which was pretty much identical less the CS cam shafts and the Mahle 4032 87.5mm pistons instead of the 88mm pistons I have now.
So what's the catch here, why do they crack? I just threw in a new set yesterday and after a few pulls another one cracked.
The sparkplugs are NKG 6510, purchased from EdgeAutosport only, and judging by their aspect, marks, markings, texture and everything there is absolutely no chance they are counterfeit.
The spark plugs are installed with a spark plug socket, and I'm always careful not to lean sideways when torquing them. Also, it never happened before, it started happening with this engine only.
- two on #2;
- one on #3;
- none on #4 (yet).
