08Speed3
Year/Make/Model: 2008 Mazdaspeed3
Mileage:140000kms engine
Concern: crank no start
DTC's: VTCS stuck open, VTCS is deleted
Modifications: intake, tip, catless dp , straight pipe exhaust,Accessport, ssqv, auto tech internals,
ECU/Tuning Software: Accessport v3
Tuner:freektune
Recent Repairs: new map sensor, intake valve cleaning, flow tested and cleaned injectors
Correction:
Dealing with a crank no start. Drove to work fine this morning, get in to go home after sitting 8 hours and car started for a brief second and died. Now car will crank but not start, disconnected battery to reset ecu and car every once and awhile will start for a few seconds and then die immediately. After it does that it will crank and crank and do nothing. If I prime the pump a bunch of times car will start, but die after a few seconds even if I try to keep it alive with throttle. Hold revs at 3k but will still die after a few seconds of running. Fuel pump resistor is jumped. Hpfp reading looks fine on the Accessport, over 400 when it starts shoots up to 1000+psi but dies still. I hear the in tank pump prime, though quiet and I don’t think I hear it everytime. Grounds are good, Hpfp ground is secure and clean.fuses all look good. I’m leaning to in tank pump failing but I’m not sure. Might try to clean Hpfp tomorrow but for now car is stuck at work.
Tuner:freektune
Correction:
