Enki
Motorhead
Additional / better / nicer hardware for the manifold install.
Also makes installing the top manifold nuts MUCH easier.
Intake mani top (and brace)(so you don't have to pull the pins from the stock mani):
ARP 400-8004 M8 x 1.25 x 51mm x 4 count ~$65
10mm 12 pt. drive head
3mm stud allen
3 total studs required
Intake mani bottom (better to use bolts in the bottom):
ARP 771-1006 M8 x 1.25 x 45mm x 5 count ~$50
3 total bolts required
TMIC front (easier to line up the TMIC; can be a pain with the grommets though):
ARP 400-8003 M8 x 1.25 x 45mm x 4 count ~$50
3mm stud allen
2 total studs required
Throttle body (just because):
ARP (770-1008) M6 x 1.00 x 55mm x 5 count ~$50
8mm 12 pt. drive head
4 total bolts required
M3 ball end hex key (makes it easier to drive in the studs): ~$8
Edit:
A couple of pics for da whiney babies
3mm stud allen
3mm stud allen
Edit:
