davychronic
You're more likely than not going to have a tough time getting things to be smooth spraying that low. If cleaning is your major concern, it'll do enough cleaning when you're WOT. Actually it'll clean better at WOT because charge velocities will be higher.
A good PCV system that doesn't pull tons of oil into the intake coupled with spraying at WOT will keep things perfectly clean.
Yea im not sure how things are going to work out, i built my base map for them to spray 1% idc until 1psi then it incrementally increases to 80% by 28psi. I wish the aem fic came with a higher pressure sensor. Im debating if i have the movivation to see if i can make a 4 bar work in its place. If not then ill be stuck with spraying the full 80% from 28psi. I do have 2 catch cans that do wonderful but a little port injection while cruising would be ideal.
