DISI-MZResponse 2.0
In before thread lock!
The pics are kind of shit but whatever, fite me.
General block shit:
  • Main bearings:
  • Block and gasket had oil all over the place for some reason (sat for months before being pulled, was not turned upside down before head was removed today):
  • Headwork:
Cylinder 3 stuff:
  • Gross (they all looked like this)
  • Rod bearings (not sure if this is good or bad or what):
And now...
*Drumroll please*
Cylinder 4 fight club:
  • Extra exhaust flow
  • Further customized piston
  • Cylinder wall not even broke in yet
Discuss!
*That's an order*
Clearly not, if you look at the pic of cyl4 wall. Still has the cross hatch. Also, all the pistons appeared to have the gaps closer than 180 deg off, suggesting that they were either rotating at different speeds or one wasn't rotating at all.
Piston rings are going to do whatever the hell they want once you fire the motor. People worry too much about where the gaps line up
They would spin differently, they are different materials and profiles and subject to different degrees of loading from combustion
Check the bore size
This was a brand new block, measured using a bore gauge several times at several spots and several depths into the bore; IIRC the difference between the narrowest measurement vs the widest measurement across all cylinders/measurements was something ridiculous like 0.005"
Custom made Wisecos with Wiseco rings. I did not have the bore honed to their spec, but I don't know what factory spec is so... Anyways, I've heard there are ring issues with Wisecos (after the fact) and lo and behold!
I still have spec sheets for both rods and pistons if you care, but not sure what it would tell you other than "what the fuck was he thinking?"
Lol
I'd rather not release them publicly as someone may try to duplicate this build and wind up running into even worse issues than I did. I can send them to you and buns though if you want.
