Indeed! No cross-threading for me. I made sure the holes lined up really nice before hand tightening everything and then using sockets to snug them down. My Dad told me a long time ago, "if a bolt/nut doesn't want to go in, DON'T FORCE IT!!!" Sage advice, haha. I adjusted the engine-supporting jack height a tad during the install to get everything lined up really well. That made everything go in hand-tight very easily, and prevented any cross-threading. Work smarter, not harder, right? LOLHopefully you don't cross-thread the frame bolts. Turned a 15 minute job into a 2 hour ordeal of swearing and baby punching.
From stock to DM PMM, you mean? I went from JBR to DM, and it feels noticeably lessened.When I installed my PMM, I didn't notice any increase, maybe a bit more perhaps.
Yeah, I meant stock. And I would assume that coming from JBR.From stock to DM PMM, you mean? I went from JBR to DM, and it feels noticeably lessened.
The bushings have died of AIDS.Honestly they still seem stiff, from inside the car. It may be a totally different situation once i pull them off. In its current state i can barely use the review for anything, at idle, reversing, or highway speed under 80mph. If the ac kicks on its sounds like an M60 is going off just outside my window.
Go Damond fully mounted if you want exceptional performance. Or, if you want less NVH, at least get their RMM and maybe even the TMM, if you don't mind a little more NVH, but don't want fully mounted NVH. Having all three mounts, I am VERY pleased with the performance, which I definitely need at my power level. Best mounts I've ever run, and my Speed is still very DD-livable.Honestly they still seem stiff, from inside the car. It may be a totally different situation once i pull them off. In its current state i can barely use the review for anything, at idle, reversing, or highway speed under 80mph. If the ac kicks on its sounds like an M60 is going off just outside my window.
Use Sure mounts as paperweights
Sent from my iPhone using my stinky little fingers
LOLThat's a danger to the poor paper. LOL
