JohnnyTightlips
Motorhead
Mazdaspeed3 SSQV Blow Off Valve with HKS Direct Fit Adapter
Purchase Date: May 18, 2019
I ran this as the new valve on my built motor. I never really felt like it was causing issues and it passed about 10 boost leak test I had done over the course of 7 months with the fresh motor.
The Good:
If you want some bad ass bird calls and are never satisfied with leaving your car alone, try it out. It might be the valve for you. I will def miss the "call to rice" but I will not be going back as the car just drives much better now.
Bonus Material
@alexwlwsn had an actual legetimate HKS SSQV and he noticed similar issues so it seems to be a design flaw rather than an ebay knockoff flaw.
The Good:
- No Boost Leaks "as far as I could tell"
- Is loud and makes sweet sweet ricer bird calls so your friends know when it is time to do hood rat shit.
- Held 18 psi and no issues while logging
- Adapter fits great and o-ring seal nicely "Use a clamp to push it into the adapter to get the C-clip in"
- Wacky shit
- Part Throttle Boost it would open if I let off the gas a little and the car would bog
- Clutch in the revs drop slower "not sure why but that changed with the tial"
- Just not smooth, over all daily driving from stop and go to on and off throttle was boggy, I did not really think much of it until I switched to a 50mm tial style and the car is WAY smoother.
Bonus Material
