iguardflorida
I'm having a problem when at WOT (or really any throttle position that's building boost). I get boost cut at around 10-12 pounds, and then it sounds like the wastegate flapper is just flopping opening up off the wastegate spring pressure. I put in a call to Corksport and they said while it's uncommon, it's not unheard of for their EBCS to fail, and that the symptoms I have of boost cut at 10 pounds on their CST4 sounds like the EBCS could be the culprit (out of warranty by several years unfortunately). I've checked the bleed setup, and at the recommendation of my new E-tuner, Dramatuning, I'm going to reconfigure for an interrupt setup. I don't have any line leaks that I can find. I'm going to throw on the new EBCS when i get home in a few weeks and will update this thread when that happens. Let me know if there's anything else it could possibly be that I should check. Thank you in advance!
