I have not bench tested the EWG yet. I can confirm it was leaking during a 32psi boost leak test. Unless I pinched the line going to it, and even then it was bleeding pressure slightly, but that seems to be expected and normal.If he has a 21lb spring in it and is only seeing 23 psi at 55% wgdc that seems pretty low. A 21 lb spring should "in theory" make up to 42lbs of boost before it can't hold anymore. He should not have to request 100% wgdc to get the turbo to spool quickly to spring pressure. It does look like the tune could be cleaned up a little but that is usually icing on the cake unless it is way off "which I would doubt with his tuner" Are you sure the wastegate is not leaking boost? Have you bench checked it with compressed air to see it open and close?
Sent from tapioca
