Speedie6
Silver Member
My turner says the idling issues I’m having just the way it is with a 4” intake and aggressive cams. Sometimes it idles smooth as glass, particularly if the engine is fairly cool and it is moderately cool outside. But say I’m in stop ‘n go traffic on a hot day. The engine gets on the warm side. I’ll inch up to the next stop. The engine RPM will drop to near the expected idle speed, but, then jump back up to around 2500 RPM. Then it will bobble for about 15 seconds between 2200 and 2500 RPM. You hear the engine UUuuuUUUuuuUUuuuUU. Then drop back down to regular idle. Then repeat again at the next stop ‘n go. I asked my tuner who replied:
Do other people experience this? Is the tuner basically correct? I’m considering trying to stuff a honeycomb air straigtenerer into the MAF. It already has a basic standard style air straightener, so my guess is that it won’t help much, but I figured it wouldn’t hurt to try.
it’s when the vehicle is on the hotter side of things what you are experiencing is the Radiator Fans pushing air towards the intake. When this happens it’s adding air flow past the MAF sensor that is not a consistent air flow and only at certain times. This unfortunately cannot be tuned for and the issue is made more present with the larger diameter intake.
