Here is how I attached the Harbor Freight Engine stand to the motor and it worked out well.
Here is how I mounted it.
You will need 3 threaded bolts m10x1.5 "length depends on stand" and 1 long thinner threaded bolt that you will but a nut on. The 3 go into bolt holes for the trans that are already threaded on the block. The 1 goes through a bolt hole that is not threaded.
