so this is my first post,
If u want to go straight to what my issue is skip the details next ill put troubleshooting in bold
I bought my 2013 speed 3 in may 2022 at 134xxxkm and its now just over 140xxxkm. since buying it I've learnt that it has a gen 1 engine, engine is "fine" (comp. 170,150,140,145) i know its not great and it burns some oil not much but it does.
Maintenance ive done: All within 5k km
oil change 5w-40 (pretty much stopped oil consumption)
Turbo doesn't smoke on idle
Added autotech hpfp before i started driving the car
cleaned valves (walnut blast)
NGK step colder plugs
Cleaned and flow tested injectors less then 1000km ago
Mods:
AP
MF CBE
COBB TIP
SURE intake
Turbosmasrt BOV
Egr tube delete (valve is still there)
Freektune at 21psi+/-
TROUBLSHOOTING
So a week after i owned the car a p0300 came up and that has been going on ever since after trying many things to fix it
so the codes that i currently have are as follows
p0202
p0442
p0300
p0128
p0441(egr code)
So sunday night im driving with my lady on a nice date and the speed decides it wants to be problematic so im sitting at a red light and then it just starts stumbling like rpms bouncing between my usual 1krpm idle down to 6-700 and back and forth. I take a look at my afrs on my AP i see 29 as well as p0202 so im like shit i need to drive around the corner and see what going on so i try and the car stalls. So i push the car out of the way and pop the hood. i look around, don't see anything usual, so i call my dad he tells me to check the fuses. One of the fuses pops back in and the car is good to go.
Now present day 2 days after that happened on my way home the car starts stumbling/misfiring I can feel it being weird. so im looking at my AFR and HPFP pressure and its absolutely all over the place hpfp was giving me very low pressures for the conditions(400 on accel.) and AFR ranged from 10-29 through normal driving. Engine light also flashed a couple different time and i had to stop the car kill the engine and restart it a couple times to get it normal again.
So that's my current issue
Should be worth noting one of my dads friends who's a mechanic told me a couple months ago that it could be my hpfp causing my misfire.
So what is going on? Has anyone experienced this before? know what to do? just any advice please, I need my car to get to school and im not sure what to do
Mods:
AP
MF CBE
COBB TIP
SURE intake
Turbosmasrt BOV
TROUBLSHOOTING
p0202
p0442
p0300
p0128
p0441(egr code)
