OKGN
Anyone know what the ohms need to be on the fuel pump resistor? Searching the web gets me varying number. Im getting 0.8-.9
Chasing an issue, trying to rule out fuel system components.
Symptoms if you are intrigued
When cold, it is long turnover but fires up and runs/drives normal.
Cleaned throttlebody and MAF sensor
Plugs were older and were white when pulled, kinda concerning, installed oem spec NGKs
When warm after starting cold, 30+ minute drive, it will randomly stall ONLY at sitting idle for several minutes
When warm starting, it will start then immediately stall. Revving above 3k will keep it alive. If I let it stall after keeping it alive by revving, it will only crank over and won't start until it cools down.
Only mod is CS short intake, unfortunately I do not have an accessport or similar tool to read fuel pressure which would prob tell me the issue haha.
Thanks!
Thanks!
