Datalog won't matter much; your O2 sensors are fucked most likely.
Enki, I hope that it's that simple.
A little but it's still rough. It did run longer. If you watch the video, that's with the O2's disconnected.Is it running smoother with the sensors unplugged?
Due to my schedule the car has sat for a couple of weeks. I start, it roll all the windows down to vent the heat and while I'm sitting there it quits and wouldn't restart.What's the backstory here anyways? It's unclear what's going on from the OP.
No rats, I pulled the tmic and looked around. Put it all back together and used brake cleaner to test for a vacuum leak, no leaks. I think I may need a exorcism on this thing. I'll check the battery and ecu next.Are pack rats a thing in your area? Might have a nest under your intake.
I haven't had time to work on it. A whole lot of bad things have happened since the last time I posted. I'll get back to it soon.Did you fix it? What was the resolution? Thanks!
I became so frustrated with the situation and lost access to the SnapOn computer that I used to get the car running, So I called a local shop that has worked on family vehicles. He had to replace the crank sensor and if I recall, It is OEM. I also replaced the purge valve solenoid as suggested by Raider. It was in in a Duralast box.That sensor has caused a lot of issues lately. Did you go OEM?
That raider guy is kinda cool.I became so frustrated with the situation and lost access to the SnapOn computer that I used to get the car running, So I called a local shop that has worked on family vehicles. He had to replace the crank sensor and if I recall, It is OEM. I also replaced the purge valve solenoid as suggested by Raider. It was in in a Duralast box.
That he is!That raider guy is kinda cool.
