Don't tell me you want to Seafoam. Please don't.
What do you recommend for valve cleaning then? Is there another product you like or would you just say to walnut blast or similar?
I had the opposite problem while I saw some evidence of leaking injectors and they were dirty dirty mine would not come loose without the puller. Even with OEM sealsSo while I had known that HAD to clean injectors / valves. Got supplies walnuts (on-line), better harbor freight media blaster... Then of course, decided to rebuild motor...
Not from any one problem just random things, kr, idle speeds, idle air fault codes..
So started taking apart using the threads help and guidance...since that close and a bought off a member a CS injector puller...stock style injector seals are really cheap....started pulling fuel manifold..This injector fell out!!!! Wonder what my problem was?????!!!!!!¡
Rest were hard from baked seals, all looked ugly. Sent out to have injector cleaning flow check done all were great. Now I know the job was done and can forget that maybe a cause. The last pic shows when you take apart stuff you may find previous owner left you a bonus problem....yes that would cause some air problems)View attachment 19462 View attachment 19463 View attachment 19464 View attachment 19465 View attachment 19466
Seafoam is great at frying O2 sensors thoug.
I used the CS valve blast tool. Look up my Christine thread on that.
Nothing works as we are not port injected. Walnut blast is just hands down the best.Would you say the same about all of those types of things? Such as the CRC intake valve cleaner and similar?
I’m not meaning to say that walnut blasting isn’t best, just wanting to gather info. (It’s fairly amusing I get a downvote for asking a simple question!)
They don't work. If it did, we wouldn't be blasting.As far as I’ve seen, I don’t disagree that walnut blasting is the best. I’ve seen videos of the results and it looks terrific.
I’m only asking because I’ve seen some videos claiming things like seafoam or CRC work to some degree on direct injection engines, with some limited ‘evidence’. I’ve never used products like those. Just gathering information because I’m sure I’ll need to deal with dirty valves at some point.
When you see the insanely tough buildup that won't even fully loosen after 30 minutes of B12 soaking, there is no way anything but a solid physical remover is benefitting the valves. (or Meth)As far as I’ve seen, I don’t disagree that walnut blasting is the best. I’ve seen videos of the results and it looks terrific.
