mstake6
I want to start by thanking everyone who helps out on this forum. I've spent so many hours reading through posts and learning just how bad an idea it was to buy MY MS6
I'm the disappointed dad of an 07 speed6 that wasn't driven for years. Of course the fuel was spoiled and I suspect there's gunk and varnish throughout. The issue is fuel pressure when the engine is hot. Cold starts are hesitant, but it starts and runs. If left to idle for 20+ minutes fuel pressure drops to around 40 psi and the engine stalls. It won't start up until it cools down. When I check fuel pressure by AP, it is extremely slow to rise and only hit 400-600 psi. I have replaced the PRV and cleaned the spill valve. There are no signs of an external fuel leak. The HPFP has CS internals and hits 1950 psi while driving. I can drive it for up 40 minutes before it stalls. The engine misfires under load, in boost, feeling like fuel cut, between 4k and 5k rpms. In fact it seems like there is a consistent misfire as long as it's running and it feels choppy at part throttle. There are no CELs currently, but I've had them come and go.
My main theory is that the check valve(s) in the pump are sticking open when hot allowing fuel pressure to somehow be directed back through the HPFP. Is that possible? And can the check valves be cleaned?
My second theory is that the fuel injectors are sticking open. I'm confident the should be cleaned.
Mods:
CS SRI (what a leaky pos)
CS Pump Internals
Catless Downpipe and Test Pipe that I put a CC on
Other info:
Engine was rebuilt about 20k miles ago
This car is making me sad
Mods:
CS Pump Internals
Other info:
