dinnerplate
Everything is back..got it back.. cleaned the MAF, the couple that popped out was the passenger side.. has the same problem like this person had..bogs around those rpms..then kicks into boost..
Only code popping are 2177/2187 (same?) so yeah.. going down the rabbit hole now
Yeah, OP cleaned their HPFP, which fixed their problem. I would suggest doing the same if you haven't.
