Mastermind46
So... one day my father and I were cruising down I-25 blaring some 2 Chainz and one of my front speakers blew out. Mazda OEM speakers suck ass.
What sucks even more ass is that the speakers I bought needed quite sizeable spacers to get them to fit without the windows hitting them when they roll down. I called some places to get these spacers made and they said they all use particle board or cut the oem speakers... end preface!
I ordered Pioneer TSD6802R 6 X 8 2-Way 260 Watt Speakers
OEM speakers off of Ebay were like $30 bucks per
http://www.ebay.com/itm/2009-2013-Mazda-3-Mazda6-Loud-Door-Speaker-Genuine-OEM-NEW-GS1E-66-960A/201583453773?_trksid=p2047675.c100011.m1850&_trkparms=aid=222007&algo=SIC.MBE&ao=1&asc=36861&meid=b09e113d685245e09b62f251f1bd2d1c&pid=100011&rk=1&rkt=10&sd=201256042915
I also did not want to cut the OEM speaker wiring harness so I spent like 60 minutes searching to find adapters... Metra 72-5602 (for select 2011 and up Ford vehicles). They were $7 for 2 off of Ebay.
Oh and do not forget to buy a bunch of the door panel snaps as all of them will break when you pull the door panel off.
First step was to remove the speaker components from my soon to be non particle board spacer... Pliers, clamp, and some sort of saw or angle grinder works great for this step.
The next step was to attach my speakers to the spacer... I originally used 3M foam double sided tape to do this. I did not want vibrations since my speakers did not perfectly sit in the spacers. I eventually took everything apart and filed down the edges on my spacers to get the speaker to seat better and used liquid silicone instead of the 3M tape... (No more vibes).
The above picture was when I was using the 3M tape.
