jsilva
I was attempting to put back together my car and was reinstalling the lower arms and couldn’t figure out a good way to do it.
I was able to get the front arm partially in by banging it in from above (with difficulty...) and when it was in far enough I put on the nut and started tightening. This probably would have worked but I didn’t finish because it required a lot of effort to turn and I wasn’t sure if that was normal, and I also couldn’t get the hub to push in anymore to get the CV axle all of the way in.
I then tried the same thing with the rear arm and it wouldn’t go more than a smidgen in.
I’m assuming there’s a better way...?
(5 and 6 in the image)
