I Can Haz Evo???
AYOUSTIN
As of last wednesday I've joined the dark side and bought an evo 8. It's a little bit modified...
- Stock longblock
- CBRD bbk-b ball bearing turbo
- ETS intercooler and piping
- ETS intake
- Omni 4 bar map sensor
- APS bypass valve
- Spoolinup coil on plug kit
- Buschur turboback exhaust
- Ported ehxaust manifold
- Ebay special O2 dump
- FIC 1100cc injectors
- Wally 255 fuel pump
- 18x10.5 NT03 w/275/35 Victra RC1 slicks
- Ohlins flag series coilovers
- Technafit braided brake lines
- Binary brake ducts
- Whiteline front and rear sway bar
- Whiteline bushings
- Sheptrans stage 2 transfercase
- Wavetrac front lsd
- Sheptrans rear diff
- 10 point cage
- Racetech driver seat
- Corbeau passenger seat
- Schroth harnesses
- Sparco 383 steering wheel with quick release
- Lexan windows
- Custom front and rear crash bars
- Custom alumilite front splitter
- Kognition rear spoiler
View attachment 6540 View attachment 6541 View attachment 6537
- Stock longblock
- ETS intake
- APS bypass valve
- 10 point cage
- Schroth harnesses
- Lexan windows
Fake Racecar, I've seen it.
crapatalk it sucks for free
It honestly wasn't as bad as it sounds. It definitely wasn't the most comfortable thing but I did Denver to Chicago straight minus stops for food and gas.
I commend you sir, that is a crazy trip.
details on turbo for this 12 sec car, plz.
It's a stock frame turbo kinda like a BNR. It uses a factory twinscroll turbine housing. It's not sold by CBRD anymore, it was supplied to them by Blouch who now directly sells their own product. It's pretty much Blouch's Dominator 2.0 XTR turbo, it flows 57lbs/min, ball bearing center housing. It's extremely responsive. I'm barely pushing it right now, only putting down around 400whp on E85. Some of the things I'd like to change this season are converting the car to speed density and moving from the manual boost controller to an ebcs to help gain control for when I decide to push power up a bit more.
Found the car has an upgraded front engine mount the other day. Good to know since I was going to order one. Making a shopping list for solid bushings for little things like the shifter and driveshaft and such.
Ideally I'd like to get the car as close to 2700lbs as I can while using all factory body panels and the factory gas tank. Right now the car sits around 2850lbs. Most of the weight reduction won't happen for another year as I need to finish paying for school but after that I'll be getting tubular subframes, a lighter driveshaft and a rear diff mustache bar delete. Still trying to figure out other good places I can shave weight from. If I get extra adventurous while the car is in storage for the winter I might go through the harnesses and takes out what wiring isn't being used.
Do the evos suffer from crankwalk?
Nah that's a 7 bolt DSM problem. Evos are relatively bulletproof minus the tcase and front diffs being weak as hell. Fortunately I've already got that covered.
[doublepost=1496422627][/doublepost]
Most mso vendors sell Evo stuff, so you got that. A Slowpok3 tune would be good too.
Yea I'm probably going to keep the tune it has for road course/autox and get our tuner at work (JR tune) to do one for the street/strip. It's really crazy how much you can do with the stock ecu on this car. I really love on the fly timing and fueling changing.
Ordered the rear engine mount, trans mount and passenger side engine mount from Torque Solutions to compliment the front one. Interesting to see how upgraded mounts do on this car compared to the speed6. Doesn't seem like a common upgrade in the evo world.
Also ordered driveshaft carrier bushings for shits and giggles. More good news was finding Torque Solutions billet shifter base bushings and shifter cable bushings already on the car so I won't have to order those. Also found some upgraded rear trailing arm bushings while I was under the car.
