Lex2007
Ive had Kw V3 on my 2007 speed3 for maybe 8 years. The rear struts have been in for rebuilding once in that time.
I am pretty sick of the harsh ride around town so I called KW and they told me they had 2 options for softer springs for the kit.
The KW V3 kits come with Front 400.05 LBS./in. Rear 192 LBS./in.
They don't sell anything softer for the rear only for the front.
The softest front springs they sell are 280 LBS./in for (Part # 60110046). $80 each plus shipping. They also sell a 340 LBS./in spring which is only 60 LBS./in softer. Thhey took a month to arrived from Germany.
I installed them along with new dust covers because the old ones were in pieces. BAD design by KW. The cover smashes down into the strut and breaks apart. WTF? $8 each but as we know its installation that is annoying not so much the $16.
Ive only driven maybe 100 miles but honestly this is what should have come with this kit from the beginning. 400 lbs/in is way too harsh.
I would say it feels like maybe 20% softer. Impact harshness is definitely reduced. I need to play with the rebound and compression adjustments now and get an alignment. The car was sitting lower so I had to raise it an inch with these softer springs to get the same wheel gap and no rubbing.
Here is old and new side by side. You can see its a thinner coil. You reuse the helper spring.
