Enki
Motorhead
Datalog2:
Tip-in for this (WOT? Don't use throttle use pedal position aka APP) pull is lean as hell (>stoich) and the part where you get knock is lean as well (>12:1). This is *probably* due to your mix.
The knock causes heavy enrichment (dipping to a solid 9.26:1) which can be just as bad as too lean. 9.55:1 AFRs and 10 degrees of timing at 5500 RPM should not be seeing any knock.
No more WOT pulls for now.
Datalog3:
Idle log.
Fuel pressure, load, AFR, trims and airflow all pretty stable. Timing swings with RPM pretty good though.
1. Pull the intake filter and check to make sure there's no crap in the intake potentially blocking part of the straightener (usually vertical bars before the MAF sensor). Start the engine like this and see if it runs better.
2. Unplug the MAF, cold start the engine and see if it starts better. If not, the issue is spark or timing related (see #3).
3. Double check the position of the crank angle sensor (re-time the crank position sensor, if off even a little bit then retime the top while you're at it).
Also need to know what plugs and heat range they are in, when you last changed the air filter, what intake you have and maybe even a pic of the engine bay so we can see if anything stands out.
Your HPFP appears fine, so I wouldn't worry about that for now, though you should probably test the E85 pump you use to verify what mix you're running (anything over about E15-E20 and you absolutely have to tune for it).
Datalog3:
Idle log.
