Hey everyone!
Brand new to these threads and the idea of being tuned for an e30 mix. I drive a 2011 MS3 with 122,000 miles on it (2nd owner since 2013 and 13,985 miles). Checked the compression this winter and all looked good (also had leakdown test done a couple years ago and it was <5% if I recall correctly).
I have HPFP internals, 3" widepath JBR intake, COBB APv3, and an eBay test pipe on the way. I will be tuned by Stratified (being a Canuck ) and I think they nearly have me convinced to be tuned for just 91 pump and a second map for e30 mix.
My question pertains to importance of the accuracy of the mix. I think it is best to err on the higher side of ethanol (I.e. tuned for 30, better to put 30%+ in the tank), with consideration to never exceed a 50/50 mix. Reason I ask is because our 91 pump gas in Canada says contains up to 10% ethanol, and based on my reading e85 can be anywhere between 70% - 90% based on the season.
Would it be reasonable to assume 91 pump at 5% and e85 at 75-80% ethanol content and base my calculations on those assumptions? Without a fuel testing kit (and what a pain that would be at the pumps everytime), not sure what my best course of action would be.
Also, I'm only considering running the e30 during summer and switching to 91 during the winter.
Thank you in advance!
Andrew
Andrew
