Intake Manifold
You can cut the pipe accordingly and get a bead done. You can also make a diy bead maker if you have the parts. Honestly, it's inexpensive to do our own kits vs having dm make mock ups until they nail a shape down and then produce pipes. When I mocked mine on my car i had issue with the pipes after the oil filter cuz fuck me.
Sent from my SAMSUNG-SM-G935A using Tapatalk
The pipe needs to come tward the radiator a bit as well so to do that with silicone bends and clamps gets messy fast. I have to use a hump connector on the tb so i can bend the pipe forward. I want a mandrel bent pipe that comes 20 degrees twards the rad then back to vertical into a 90 degree pointing to the dr side. Then after that its all tits and lube bolt on fun!
Pfffffffff. Pretty sure no one's recirculating by that point.
I will be if I choose the Gen II GTX3071r. My 2010 hates VTA, even with a GA. I could never give it fine-tuned without compromises. If I go EFR7163 instead, no worries because the BPV is integrated into the compressor housing.
I am still recurc. Vta isn't my cup of tea so to speak. A 1" silicon hose works just fine. I got mine from siliconeintakes.com The oem line is 1-1/8" so it takes a bit of streching but nothing a bit of silicone spray couldn't handle. I ran mine before the frame rail not around it so maby 2.5/3 ' of hose. Id post a picture but photobucket is holding my shit hostage ATM.
I'm still recirc too for the most part. I got my hose from flextech. As you can imagine, it flexes.
I just realized this thread existed haha. I've been running the DM for a little while now. @m00secakez that pipe is beautiful but damn that's expensive! Too much for my blood.
Such a nice pipe though! I originally bought the piping and couplers that Ozzy and Erik referred to me but I returned them because I prefer less couplers and the price difference was only about $40.
Well if the difference was only $40 yea I'd go with that but shit. I'm gunna try and have a local shop make one of those for me. Or my brother if his work would let him haha.
