Boost_creep
I wanted to start a discussion to get people's opinions/observations on the different FMIC cores on the market. I am running a CP-E tmic at the moment, making roughly 420whp, on a gtx3071. But as we all know, we need moar power! I did have the Cobb v2 piping kit with a TR8 core, and absolutely hated it. You can see my discussion on that here:
http://www.mazdaspeedforums.org/forum/f293/p0113-high-iat-s-173210/
To sum the thread up, I installed the kit and saw much higher BAT's and ECT's than I have ever experienced. It either was the ic core heatsoaking the radiator, or the other way around. My BAT's were so high that if I stayed at idle for more than 5 minutes, I would throw a "maf circuit high" trouble code. So no bueno. The kit came off, and everything went back to normal. That is why I still run a tmic to this day, and it makes me ask the question, why is no one else experiencing this?
So with that being said, the first (and most common options) are the Treadstone TR6, TR8 and TR8L cores. I really want to stay away from these cores, just because of my previous bad experience. Whether it was the piping design or the core, that caused my issue, I do not know. But this time around I plan to use JBR's undermount piping kit. I'm hoping this will quell some of the heatsoak I was experiencing. Feel free to chime in here if you are running one of the above cores, and either experience, or do not experience, high BAT's since the install.
There is one Treadstone core that has peaked my interest, and that's the TR11. Same width as the TR8, so it will work with JBR's piping, but it is a few inches taller. This will require cutting the crash bar. I'm not too keen on that at the moment. Is anyone else running this core? Here is a link to cld12pk's experience with this core on his Gen1:
http://www.mazdaspeedforums.org/forum/f33/how-install-treadstone-tr11-intercooler-120888/
I've been searching around the interwebz for other cores of similar size and came across 2 others. The first is the Spearco 5-383 core. Capable of 550hp, and only 2 inches wider that the TR8, at the same height. I should be able to make it work. Does anyone have any opinions on this core? I know Spearco is a very reputable company and has been around for roughly 35 years. They must be doing something right.
https://turboneticsinc.com/store/index.php?route=product/product&manufacturer_id=12&product_id=105
And lastly, I came across a Garrett ATP-INT-003 core of similar size on ATP's website. I do not have any direct experience with these cores, but I thought I have heard @rfinkle2 mention them before as being a higher quality piece. If anyone has any input on this core, I would love to hear it, as well:
http://www.atpturbo.com/mm5/merchan...tp&Product_Code=ATP-INT-003&Category_Code=INT
Whew, ok I think that's enough blabbing. Ready, set, go!
