kryptonite1055`
Year/Make/Model: 2013 Mazdaspeed 3
Mileage: ~79000
DTC's: P0606
Modifications: Cobb intake, Cobb turbo inlet, Cobb HPFP, CP-E intercooler
ECU/Tuning Software: Cobb Accessport V3
Tuner: Stage 1+
Is the concern intermittent? Yes
Recent Repairs: Replaced battery and cleared
Went on a trip about 6 months ago and when I came back the battery was dead. I have noticed a slow start in the cold, so I replaced the battery. Fast forward a month my car was parked in my driveway, it rained the day before, slow start and A LOT of engine codes, but running ok. Thinking it's a short or grounding issue. Cleared the codes with accessport. During another rain, neighbor notices my headlights are on in the driveway. Try to turn off headlights without any ability to do so. Started the car and was extremely rough. RPM limited to ~1800 and no power, mutiple codes return. Took it to the shop and they cleared out debris from in and around the cowling, reset codes and appears to work after a day (dried out). Fast forward to two days ago. Rained again, hard to start, no power, only P0606 code. New symptom noticed- the rear hatch won't open when the rough idle/ no power. All other doors work buttons work. A day goes by and dries everything out. Jump the car since the headlights would not turn off again, cleared the codes again and car drove normal... rear truck button work again.
I THINK there is a water leak somewhere in the back (nothing is visible) of the car causing a short. I don't think the ECU is the issue even though I am getting a P0606 code. Any recommendations on connections or items that are likely to leak towards the back?
Mileage: ~79000
DTC's: P0606
Tuner: Stage 1+
