Hello all,
I have been having a problem where the car stumbles a little when idling. The biggest problem is that it is intermittent. Most of the time (when the problem does occur) it idles poorly for a couple of seconds and then smooths out. Very rarely the car will stutter slightly under normal acceleration but it has not happened in a couple of months. It seems completely random as to when it happens. No noticeable problems when cruising/WOT. These problems started a couple months ago and I thought I traced it down to a MAF sensor that was not fully seated in the hole but it did not seem to fix anything. Car has an OTS by Freektune, CS CAI, HPFP, fully catless, stock catback, new sparkplugs (stock heat range). I could not find a boost leak last time I checked, I tested the purge valve solenoid, unplugged the MAF when it was acting up and no apparent change to engine smoothness. I have attached a log from when the car seemed to be running OK (datalog15) and a log from the final revision of the tune in February of this year (idle1). Unfortunately, I don't think I will be able to get a log from when the car is acting up because it is so random. I am out of ideas for what is going on and looking for any direction. Thank you!!!
