Update:
I put some actual fuel clamps on the lines and it looks classier now. My barbed fitting for the AN6 never arrived so I am using the fitting I have which seems to be fine. It is so tight I can not pull the hose off without cutting it so I don't see having any issues.
I pulled the pedal assembly and master out, what a pain in the ass. It was not as bad as people say but it's very much dumb compared to other cars like my old DSM which was two bolts and took 10 min. The hardest bolt to reach was the top one but I was able to get it with a long ratcheting flex 12mm. It was pretty hard to break them loose but once they were loose they came out easy.
I recommend you get a silver marker and mark both the master and the pedal where it needs to line up before final fitment. Otherwise it is easy to get lost when you are under there and swearing. There is only one want for the master to go into it and you can turn it by hand enough to get it started but then I needed some channel locks.
My spring popped out when I was taking the pedal out and took some casualties with it. You can see in the pic below it broke the plastic bushing when it popped out , on both sides. I could tell from 165k miles of use they had also been worn down a lot. I looked for replacements but I didn't see mazda selling any separate and entire pedal assembly.
I happen to have some 1/4" copper nickle brake line hanging out and it fit perfect so I used the brake flare tool to make my own bushing. I lubed it all up really well with silicone lube. Was pretty proud of myself for thinking of that fix as I did not think I would find a solution.
Like a glove
For reference , spring thickness all around is 3.5mm
I went to install the new supra slave cylinder which should better match OEM bore and noticed it was very close to the oil cooler and might rub. I have some ideas to fix this but am waiting on parts to arrive before I can bleed it all and get the car back up and running. I had thought about turning the cooler but it has a notch and that might already be at max position.
I ordered some parts to make my own hardline off the slave that turns a 90 into a 3an. This will give me about 5mm more space as that fitting is shorter and I don't need to adapt it.
I also installed my WOT box shift light. Will be nice to try it out.
Thant's all for now, hoping the get the car back on the road before this weekend so I can do some pulls.
