Yikes lol Surprised it worked like that too but glad you found it sooner than later!Well my PI stopped working and/or was getting flaky. It was happening more so when it was cold out "freezing temps" and I was not sure if it was a pump issue or something else. I took the bumper off and tested the pump which worked without issue. I checked fuses and everything was good. So I decided to check the relay.
Turns out it is not very waterproof..... I did have it mounted so that the wires were up so maybe the water was seeping through that. I am very surprised it was working at all.
I ended up changing location and flipping relay so it is pointing down. I cleaned up the harness and put a new relay in there. Fired right up.
I did have that on there before but I try to not go too wild with that.You could add dielectric grease to the pins for the relay connector. It should prevent moisture build up.
ThisThe hood is taller and the fenders are taller to tie in according to the online parts lists Mazdaspeed fenders are a different part number for both gens
You know this is true on gen 2 because otherwise a bunch of mzr's would have factory hoodscoop hoods put on them
Gen 1 would have to be the same to accommodate the tmic
Good to know that I went the route I did then.The hood is taller and the fenders are taller to tie in according to the online parts lists Mazdaspeed fenders are a different part number for both gens
Which is weird because they guy showed me where he was looking up parts at the body shop and it said speed and the part numbers were the same. Maybe that data was just bad?sounds like your yard is more knowledgeable than your body shop.
Yeah I have been planning to sell it for some time and move on to another project. Car is a ton of fun and a little ripper but I am just ready for the next one. I pretty much did all I wanted to do and learned a ton. I like the tinkering and learning even more than the driving which I know is not always the case. Everything is good and I will be driving my backup car "van" until I find the next one.What made you decide to sell it? Everything ok?
