Rockyyy999
Year/Make/Model: 2006 Mazdaspeed 6 GT
Mileage:164000
Concern: So I've had to top up the oil twice within the past week. On Friday I checked the oil and it was at the very bottom of the dip stick so I put about half of a 5q bottle in to get it to full. Today (Thursday) I checked it again and had to add almost the rest of the bottle. I was on a road trip when I added oil the first time so I did put about 700ish miles on it. I know the pivot shaft seal is leaking but I don't think I have any other leaks at all. Would the pivot shaft seal cause this or would it be leaking trans fluid? Sorry if that's a stupid question but I am just starting to get into working on my own cars. This is my second car I've owned and I would like to learn.
DTC's: None
Modifications: JBR short ram intake with turbo inlet pipe, Cobb rear motor mount, Corksport 3" catless downpipe V1, Autotech HPFP internals, Modified C6 Z06 catback exhaust straight piped, Versatune OTS high output downpipe+TIP 91oct tune, Turbosmart dual port blow off valve, Full EGR delete, VTCS delete, JBR short throw shift plate, and BC racing coilovers.
ECU/Tuning Software: Versatune
Tuner: Previous owner
Is the concern intermittent? Doesn't seem to be.
Can you duplicate the concern? I don't know
Recent Repairs: Transfer case, transmission, and rear diff serviced 20k miles ago. All 4 cv axles replaced 15k miles ago.
Mileage:164000
DTC's: None
