Evoedgar
Yes I did.Did you route the cans as per the diagrams above? With check valves?
Things I’ve checked off already:To be honest I don't remember what fixed it. A I did a bunch of different stuff, and B I've had so many problems I don't remember what fixed what at this point. Having the injectors cleaned and new plugs was one of them. How do you have your cans run? Have you done a compression/leak down test? Do you have upgraded injector seals, or are they stock?
Sent from my SM-G975U using Tapatalk
At idle it’s completely fine. After having the battery unplugged for so long to switch the injectors out(waiting on delivery), the code went away and didn’t come back up until I went to test drive around neighborhood. Idle was stableIs it a noticeable misfire? Running and idling rough, or are you just getting a code?
